G makes a squalling noise
used to be jame
04-29-2006 13:25:03
I've recently acquired a G and got it running thats been sitting in a barn for quite a few years. It makes a squalling noise which sounds a lot like what a dry throw-out bearing would sound like. Doesn't seem to matter if the clutch is in or out. Comes and goes. Seems to be most constant at higher rpms. I don't hear very well, but it also seems to be coming from the mag area(right or left, I can't tell).
Any ideas?
Thanks, James
BushogPapa
04-29-2006 20:55:53
 Re: G makes a squalling noise in reply to used to be james, 04-29-2006 13:25:03
I will bet the front fanshaft bearing needs greased...!!! Take the square plug out and put a grase fitting in it's place and pump some grease in it...!! The sound of that bearing squalling goes down the fanshaft and sounds like it is coming from the governor... Try that 1st..!!!! Ron..
greenmech
04-29-2006 18:08:29
Could be your mag bearing . They need a bit of oil sometimes . Ron Mn.
F-I-T
04-29-2006 14:43:07
Get a stethoscope or use a piece of garden hose and check around the governor/mag area. Try to locate it and try to find out what seems to cause it. If the thrust bearing in the governor is binding and crawling to the left and bouncing back into position to the right can make a spalling sound, which is the race spinning in the governor case. Re-working that can be a tough chore to bore it and re-sleeve it.
If it does not come and go with the engaging of the clutch, then it is probably not the bearing in the pulley, which only turns when the clutch is disengaged. With the clutch engaged, the pulley is part of the crankshaft.
Frank
