1940 BR manifold
Marty Z
04-29-2006 11:04:22
Just got the manifold off of the BR and man is it in bad shape. Already has been patched and 2 ears are missing. The surface that bolts to the head is so bad that a gasket may not even seal. Is there some one out there that has after market or should I go to Deere. Does any one know the aprox. cost so I can prepare for sticker shock.
Thanks
Marty Z
F-I-T
04-30-2006 21:13:46
 Re: 1940 BR manifold in reply to Marty Z, 04-29-2006 11:04:22
Marty:
According to my two cylinder club serial number listing it looks like you are talking about a BR in the 329,--- to 332,--- range, so according to my parts book, that manifold would be P/N B 1348 R. Since you say "two ears are missing" I think you are meaning that yours should have the square, 4 ear exit port, straight out to the right side, perpendicular to the frame rail, not to the front like all of the row crop "B"s do. The illustration in the book confirms that a '40 BR would require the 4 ear manifold.
B 1348 R shows no longer available at JDParts.com
I cannot find a 4 ear straight to the right port at any site or in any of my books, which is one reason that yours has not been replaced before now. I have seen them modified from new reproductions, suing cast iron welding like my favorite "Muggy Weld".
You might try Melanie at Sharp's (www.oldjd4u.com) as she generally has a good feel for where things like that be bought, but be prepared for some sticker shock, as I think those early BO/BR manifolds might not be in reproduction.
Frank
Marty Z
04-30-2006 21:41:46
 Re: 1940 BR manifold in reply to F-I-T, 04-30-2006 21:13:46
You are right- The manifold has a 90 degree to the rail , port.
May have to re think this old manifold and get it patched some more. Not to mention the studs that are now fused into the casting.
Thanks to all
Marty Z
Marty Z
05-01-2006 21:56:16
 Re: 1940 BR manifold in reply to Glen in TX, 05-01-2006 10:15:01
Thanks Glen,
You may not have heard the last of this one. I will keep checking and in the mean time I think I'm gonna soak this one in some FIT waters and see what I am left with. I may have to patch and re patch to get this one to work but I have not given up. I will make some calls and keep working on this one as plan "B".
Thanks for all the checking you and the guys have done.
Marty Z
Glen in TX
05-02-2006 06:34:25
 Re: 1940 BR manifold in reply to Marty Z, 05-01-2006 21:56:16
It might pay later for you and others to keep bugging the suppliers I mentioned as they are the ones that got the all fuel manifolds finally made again. I was reading back in archives here and other places and there is a need for that BR manifold it sounds like and you will also notice a guy from England on here had been welding on his BR also. We had to take manifolds for early Ds we restored years ago to specialty casting shops for repairs but now Rosewood Machine has those made new again and our casting repair shops here all closed during the last oil bust.
Marty Z
04-30-2006 21:44:15
 Re: 1940 BR manifold in reply to P Browning, 04-30-2006 06:30:49
Got the Email Thanks.
Glen in TX
04-29-2006 15:31:46
They are available aftermarket. The ones I can get were similar to B2472R for $115-120 and another one like the Johnson cold manifold similar to B73R or B1313R for about 240.
Marty Z
04-29-2006 22:15:35
 Re: 1940 BR manifold in reply to Glen in TX, 04-29-2006 15:31:46
The parts manual lists it as #1348 and as close as I can figure from what is left of the casting it shows # B1348R.
Is this the same as # B 2472R bolt pattern and hook up to muffler pipe? I would like to get the cheaper one if I can.
Thanks
Marty Z
Curtice Ohio
