JD 40 hydraulics
donwisc
04-29-2006 07:55:14
Got a dangerous situation on my 40 3 pt. The lever will not hold the load in place and will raise by it self unless I put the lever ahead of the stop. There is a friction assy on the shaft that appears to be worn out. There is no adjustment to tighten the spring and the assy seems to be assembled and welded so there is no way to take it apart. Any help on how this assy is made would be appreciated.
lroy
04-29-2006 19:38:23
 Re: JD 40 hydraulics in reply to donwisc, 04-29-2006 07:55:14
Are you talking about the two levers with the nut that holds them on the control shaft and the internal spring that keep presser on them, there is two or three bolts that hold it to the front quad , it should just slide out , once you take it out you will need needel noise pliers to hold the crank control throught the fill hole and slide the shaft back in .the load raiseing by itself ,It might just be adjusting your levers to keep them from working against each other.there are two small bolts on the outside lever loosen and adjust jour travel all the way back on outside lever should leave you about 1 1/2 " of free travel of lift links
