80 john deere
donnie with dee
04-29-2006 06:34:05
I need some help, after i changed the fuel filters,and bleed them,the tractor lost its prime and can't get her gonin. Can anyone help!!
Bobcat
04-29-2006 18:57:59
 Re: 80 john deere in reply to donnie with deeres, 04-29-2006 06:34:05
As I recall years ago on a 70D, sometimes someting would get "gummed up" on the injector mechanism and it would be pretty muley until we had them cleaned up.
Bobcat
buickanddeere
04-29-2006 17:31:58
Did you crank the fuel filters down too tight or not tight enough? Either way they will leak/seap air.
WeirdDeere
04-29-2006 15:04:54
Sometimes my 80 has been picky, and I've had to pull it a bit to get it to run.
But the last time I had some luck and got it to run on its own. Start from the glass bowl, get it full, make sure you fill the metal canisters with fuel before installing, and just use the bleed screws, from back to front, until you get no bubbles.
Good luck,
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
F-I-T
04-29-2006 14:37:29
Are you bleeding it at all three places? Two at the filters and the third and last one is at the end of the fuel rack. It should fire right up if you bleed it properly.
Frank
deib
04-29-2006 07:17:36
On My 70 i have to run it a coule of min cranking on de compressio with trolle open so fuel should be injected. this get the last air out of the lines. And it fires right up.. Deib
