48 A squeaking
jd jerry
04-28-2006 20:26:12
I just replaced the cam in a 1948 A and now the center two rocker arms are dry and squeaking. The outer rockers are well oiled. Do the push rods get oiled on this? There is a film of oil on the rocker arm shaft but that is probabily from assembbly. I changed the carb and now the motor wants to run wild. Checked for binding linkage and that the throttle linkage was a half hole off.
BushogPapa
04-30-2006 08:58:45
 Re: 48 A squeaking in reply to jd jerry, 04-28-2006 20:26:12
Before you tear into anything, Grease the Front bearing on the fan-shaft...!!
People forget to grease this, and the squeal sounds like it is coming from the governors... You may have to replace the plug on top of the bearing housing with a grease fitting, if it has not been changed before.. Do it while the engine is cool, or you are gonna get burned by the exhaust...!! Ron..
Mike M
04-29-2006 12:28:52
Those noises you hear are that 80 HP blowing it apart !!!
I'm betting a dyno check would reveal something more on the order of 55 HP area.
Drew
04-29-2006 12:38:42
 Re: 48 A squeaking in reply to Mike M, 04-29-2006 12:28:52
I agree with you that 55hp sounds like a much more reasonable figure; assuming it is in peak tune.
ricedaddy
04-29-2006 09:08:06
Just wondering what size tires you have on a "A" with that kind of horse power 23.1?
jdjerry
04-29-2006 10:00:13
 Re: 48 A squeaking in reply to ricedaddy, 04-29-2006 09:08:06
The tires are 13.6 X 38 . If you were going to pull it it would need more rubber on the ground. It is my sons tractor and he went out in the bone pile and said there are two rims, hubs and wheelweights on a parts A that are good so he is going to dual it up.
Drew
04-29-2006 06:10:19
In stock fashion, there are not holes in the rocker oiling tube for the intake rockers. Theory being that it wont suck oil past the valve guides and burn it.
Throttle linkage a half hole short is correct. Has the carburetor been rebuilt? It may have an air leak somewhere allowing it to suck air in. With the engine at idle, spray some WD-40 around the carburetor and if the engine speed picks up, then it is leaking air somewhere.
JDJerry
04-29-2006 07:29:30
 Re: 48 A squeaking in reply to Drew, 04-29-2006 06:10:19
The carb and cam just was done by Roberts. This A should be close to 80 HP. This was a trator my uncle bought 30 years ago and it was set up this way then. The oil pump drive gear broke is why I had it apart. All he used it for was for a extra loader tractor. I am going to check and make sure the govener is oiling. Could a oil passage be plugged? Do the push rods get oiled some how? They are dry where they go in the rocker arm. She ran good till I changed the carb. It is a Big nut carb with a few modifications and it ran good for a few minutes with that on. I hooked on to a 21' 6" disc and it pulled it fine in 3rd the disc was dropped in the ground that had been worked before. It did bring the temp up so I shifted to 2nd
P Browning
04-29-2006 08:46:15
 Re: 48 A squeaking in reply to JDJerry, 04-29-2006 07:29:30
JERRY -- you need to pick up the phone and talk with somebody! You are trying to work too many problems in one thread, and with scant information to boot.
Let's eliminate a variable or two. On the conern you have for governor oiling, find the 1/8" NPT tapped hole on the right-rear side of the governor case. In essence, this is a drill plug for the oiling channel to the fan drive & pinion gears. Remove whatever is attached (gauge, or a line to the gauge) and then use a small wire or drill bit to ensure the horizontal part of the path is clear.
It appears you have made a technical change in carburetion. One good test would be to reinstall the prior carb and do a test run.
Have you made a change in the cam??? Too many changes at one time leaves you in the dark as to what change brought about your present difficulty. Also -- 80 HP is (IMHO) a real stretch for an "A" tractor, but then I have no idea what else you have "under the hood".
As for the tappet oiling issues you describe -- not enough data is presented. If you just overhauled -- I would think you would have dosed the rocker arm area with some spary lube like STP or WD-40 to get the assembly safely through the "start up" period.
I can be reached at (830) 627-0430 if you want to probe my feeble brain some -- can't promise much, but one never knows what is learned from a casual conversation. (PatB)
jdjerry
04-29-2006 10:28:23
 Re: 48 A squeaking in reply to P Browning, 04-29-2006 08:46:15
Got to check the oiling problem first. It ran flawlessly for a bit after we put the G carb back on. It was sent to Roberts for a stem repair and we had him go through it and had a air flow tweak done to it. Whatever was done to the tractor years ago was done when it was used for plowing with a 3 bottom plow. It has a power block that is bored out to 6 1/8 inch, fancy head of some sort, G carb that has been modified and I don't know what else. The innards are in great shape because the man died before he got to use it much. My uncle picked it up because it had a wide front and it was cheap. He took the loader off his G and put it on the A. He never used it much because it was hard to steer. My cousin started it a year ago and the oil pump was froze and the gear snapped instead of the coupler. When he saw it was not the coupler he sold it to me for $500. My son said I got the last two cylinder and it was his turn so I guess its his toy now. I know that it makes my 620 look weak. Now the good part is my son is gone all summer and I get to play with it myself. I need to find something to use it on. I'm going to try it on a 20 wheel rake. The steering binds even with out the loader on and the live hyd pump is leaking but I need to get the other bugs out before I look at that.
Drew
04-29-2006 08:35:20
An 80hp "A" for a loader tractor??? You would have to have somewhere in the neighborhood of 500 ci to make that kind of power, and then it wont be on "cheap" gas. Which Robert's cam did you get, a stock grind or his "competition" cam that has a mile and half of lobe lift?
If the exhaust rockers are getting oil, then the oil passage thru the block and head are unobstruted. The govornor gets oil from a tube the comes out of the filter head and fastens to a fitting in the main case right under the governor that mates up to a hole in the gov housing. When you put it all back together if the gasket didnt line up just right or if you used RTV and a bugger of that stuff got in the wrong spot, then it is possible you arent getting oil to the governor. But that wouldnt make the intake rockers squeak.....
The pushrods do not get directly oiled. I would smear some assy lube on the ends of the pushrods and call it good.
jdjerry
04-29-2006 09:53:53
 Re: 48 A squeaking in reply to Drew, 04-29-2006 08:35:20
The competion grind. The oil flows to the rockers real good according to my mess on the floor from starting it up with the valve cover off. The squeak might be in the governor. My hearing is not to good and I think the A with a muffler is as loud as my G with a straight pipe so I was a little deafer than usual. I'll have to check it out tonight to see if the governor is oiling. I suspect the gasket is out of place. I lubed everything with some assy lube and have run it long enough for that to wear off. There is something wrong with my steering wheel crank starter shaft also. I can't turn it over with it.
spoker
04-28-2006 20:40:30
check your oiling tubes above the rockers. you might have them stopped up. The half hole on the throttle is to much. it needs to drop into the bell crank hole with not much presure applied.
