JD 4640 governor
Prairiedog
04-27-2006 16:28:38
Tractor engine "lopes" or oscillates when it idles and also at high rpm with light load. I'm guessing the governor is worn out as the pump has about 4,000 hr. on it. The tractor still pulls OK. My question is, can the governor be rebuilt without pulling the pump?
msb
04-27-2006 19:27:14
 Re: JD 4640 governor in reply to Prairiedog, 04-27-2006 16:28:38
Agree with Bob The supplementary idle spring might also need a little tweaking too concerning the slow idle oscilation.
prairiedog
04-28-2006 16:33:30
 Re: JD 4640 governor in reply to msb, 04-27-2006 19:27:14
OK. Where is the supplementary idle spring located. Or, better yet, where can I obtain a diagram or schematic or manual for this pump and or governor.
msb
04-28-2006 20:10:24
 Re: JD 4640 governor in reply to prairiedog, 04-28-2006 16:33:30
Its on the rear of the pump.Looks like an adjustment screw of sorts.Its about half way up the governor housing.Its been so long since I was at service school on those pumps,I can't remember how to adjust it.If you try, it would be a good idea to mark the position of where it is before so you csn return the adjustment to where it was.Don't go more than a quarter turn or you can cause the governor linkage to go over center and run away with itself as I remember.
You have to remember this is German engineering.Ever work on a Volkswagen?Well the governor linkage on those pumps make a VW look like child's play.No offence ,but if you had a schematic, you probably wouldn't understand it.Its VERY complicated.
Bob
04-27-2006 16:54:46
That is a common problem with those pumps. To do it right, it must be pulled, repaired, and run on a test stand for calibration. Likely, it's time to replace the "O" rings on the injection plunger barrels anyway.
