720 Diesel Govenor Case
Chatermb
04-27-2006 06:38:01
The way I read the JD service manual, the govenor case on a 720 diesel has dowels to locate it correctly to the crankcase. I was watching for them when I removed the case but never found them. In looking at the bolt holes in the case two holes look larger than the cap screws that came out of them. Are the dowels the manual refers to, a cap screw with a shoulder? If so, where can I buy them?
F-I-T
04-27-2006 07:19:19
 Re: 720 Diesel Govenor Case in reply to Chatermb, 04-27-2006 06:38:01
third party image
There are two shoulder bolts, B 1693 R, used to locate the governor case. JDParts.com shows them NLA, so you might need to check with a salvage yard. A couple of bucks should buy the two called out since they are generally a non-wear part and most often are correctly retained for re-use.
Otherwise, look around at places like Grainger or McMcaster-Carr, or supply hopuses that serve die builders. Those fasteners are popular in the deep die trade. Most shoulder bolts today are socket heads.
Frank
Chatermb
04-27-2006 09:25:24
 Re: 720 Diesel Govenor Case in reply to F-I-T, 04-27-2006 07:19:19
Thanks for your help. I already looked at a 720 in the local scrap but found only normal cap screws in its govenor case so it appears lots of people did not realize what the "funny" bolt was for and discarded it. I am buying a used govenor gear from Polk Equipment so I'll ask them if they have B1693R in stock.
Mike M
04-27-2006 10:26:27
 Re: 720 Diesel Govenor Case in reply to Chatermb, 04-27-2006 09:25:24
With that B prefix on the part number those bolts might be the same as used in other tractors like a B gov. Alot of those around for parts. I don't have my parts books handy to check it out for sure.
Chatermb
04-27-2006 12:47:13
 Re: 720 Diesel Govenor Case in reply to Mike M, 04-27-2006 10:26:27
I'll keep this in mind. However JD wrecks of any sort are not common in my neck of the woods. I am surprised the local scrap yard has even two well picked over wrecks which I think are 720 diesels.
