Help determining model and year for 4 cyl. John De
Mel1
04-27-2006 06:14:19
Need help determining model and year for 4 cylinder Diesel JD Farm Tractor. Have the following info:
Tractor Model type: 5r3h
Tractor Serial #: 076900
Motor type: m53tr Motor Serial #: 118299t
Would appreciate any help in determining the exact model number and year.
Bob
04-27-2006 09:24:45
 Re: Help determining model and year for 4 cyl. Joh in reply to Mel1, 04-27-2006 06:14:19
My GUESS... which is worth exactly what you are paying for it is:
5 = 2020 and 2030 series
R = Row Crop
3 = Diesel
H = Either High Crop or means "2-speed Hi-Lo transmission".
Does it look anything like this GAS 2020 found in the Web?
Third Party Image
If yours is a 2020, serial # 076900 would make it a 1968 model.
Hope this helps!
Mel1
04-27-2006 10:41:45
 Re: Help determining model and year for 4 cyl. Joh in reply to Bob, 04-27-2006 09:24:45
Bob - Fantastic. That certainly does help. I cannot view the photo you've attached, but I will look for one on-line. May I ask what you use to translate the characters in the model type? Is that information available somewhere on the web? Thanks a bunch!
Bob
04-27-2006 14:28:46
 Re: Help determining model and year for 4 cyl. Joh in reply to Mel1, 04-27-2006 10:41:45
Google Deere 2020, and select "images".
Here's a couple os sites that have some detail on the Deere model codes:
Link
Link
Ten-Twenty
04-27-2006 09:19:58
Mel1,
From the information given, it would appear that you have a 1968 2020 Row Crop Utility with the optional High/Low transmission feature.
Mel1
04-27-2006 09:25:18
 Re: Help determining model and year for 4 cyl. Joh in reply to Ten-Twenty, 04-27-2006 09:19:58
Ten-Twenty -
Thanks for the reply.
Which numbers matched to that?
