48
brad 1
04-27-2006 05:36:48
oil seepage comming from the inside of clutch pulley assembly, onto outside of pulley and then under hand clutch pad... called john deere, and they said there was no seal on that side of tractor... any suggestions..????? ?????
brad 1
04-28-2006 15:19:40
 Re: 48 in reply to brad 1, 04-27-2006 05:36:48
it"s a 48 "G" . so if this hole is plugged , it will cause the oil to run out and onto the outside of the pully assembly????? ?
Mike M
04-27-2006 06:30:10
No seal in there just a slinger. Check your engine oil level and make sure it's not overfull or diluted with gas. If the pulley or slinger happen to be rubbing the dust shield behind it they can leak worse. Check this dust shield to see that the drain hole is also open. To do this the clutch has to come out and the pulley needs to be removed from the tractor.
brad 1
04-27-2006 12:20:58
 Re: 48 in reply to Mike M, 04-27-2006 06:30:10
oil drain hole? tell me more,,havent heard of this one....and how big of a hole is it??? can it be gotten to from the outside? and maybe blow compressed air through it??
Mike M
04-27-2006 18:24:04
 Re: 48 in reply to brad 1, 04-27-2006 12:20:58
What model do you have ? I think by 1948 the A"s and B"s had this drain running back into the reduction cover. Once you get the belt pulley off you will see the tin dust shield which is made of two pieces spot welded together and this has a trough where the slinger runs and it collects the extra oil and runs it back into the reduction cover. There is usually a gasket behind there and you should see the drain hole.
