JD 412 plow
Chuck NH
04-26-2006 19:15:48
I recently purchased a JD 412 3ph (two bottom) for my 40T. They appear to have little usage and kept undercover. The marking 412 is still quite visable on the rear frame. The frame measures almost 14" accross and the coulters are set at 13 3/4" apart indicating to me that this is a 14" plow. However, the paint markings on the rear of the moldboards are HS326NC. If I'm reading my plow bottom parts catalog correctly, these would be 16" moldboards. Is it common to have 16" moldboards on a 14" frame and if so, why? The plow still has the small round tin tags attached to the moldboard hardware, so I would beleive this was the way they were assembled at the dealership.
Glen in TX
04-27-2006 18:34:39
 Re: JD 412 plow in reply to Chuck NH, 04-26-2006 19:15:48
I have some manuals on the 411 one bottom and 412 two bottom and doesn't show any options for 16" bottoms or those numbers in parts list in back. The 411 one bottom did use 14,16,or 18" moldboards while the 412 was listed with using 10,12, or 14" moldboards. Someone changed yours to 16 or put ones on from a 411 but 16 was not shown as a standard option for the 412 in original operators manuals OMA401052 that I have. Maybe it was what the dealer had or they set them up that way to cover more trash? The JD 415 2 bottom and 416 3 bottom plows with trip standards used 12 & 14" bottoms and were also 3 point plows recommended for the JD 40, 420 sizes of tractors.
Chuck NH
04-27-2006 19:18:26
 Re: JD 412 plow in reply to Glen in TX, 04-27-2006 18:34:39
Thanks Glen, thats sort of what I'm thinking that they were installed by the dealer to cover better. I was visiting with a friend today and he was getting some plows ready as well. He has a set of 810 two bottom 14" trip plows with 16" moldboards as well. For what ever the reason, it must of been common knowledge for some people..... I'm going to try my 412 in another couple weeks, just waiting for the brace between the landwheel and rear moldboard.
