1938 A fuel problem
BobinKS
04-26-2006 19:00:38
My 1938 A will fire on the RH side pretty well but the left side seems to begin to fill with gas fairly quickly. The float level in the carb is set correctly and I have adjusted the idle and load needles a number of times. Is there something I am missing? Can I lower the level in the carb and still get enough into the cylinders? Any suggestions
Glen in TX
04-27-2006 23:20:03
 Re: 1938 A fuel problem in reply to BobinKS, 04-26-2006 19:00:38
Yes, you could lower it some. Use a hose barb fitting in the bowl drain hole and some clear tubnig and hold hose along side of bowl and should have about fuel level about 3/4" from top of bowl line. Shut the sediment bowl valve off when it's not being used also. If the carb bowl was rusted bad and pitted in the area for the needle seat and gasket it could leaking there some too. Make sure the float doesn't haven't fuel inside it by shaking it listening for for fuel inside. Can also check float for leaks by holding it with a pair of pliers in a pan of hot water (not boiling) and watching for air bubbles spewing out at a hole in float. If you are good at soldering you can repair it or new ones are available also. You'll find carb tools, parts and clean out drills at link.
