F725 mower deck
gene leonard
04-26-2006 10:09:12
I have a bad battery, i jump start the mower. Am buying new one this week. Would bad battery not allow the mowing deck to start? everything else runs great after jumpstart.
thanks
gene
johns48b
04-26-2006 15:04:59
 Re: F725 mower deck in reply to gene leonard, 04-26-2006 10:09:12
i wonder if leaving another battery hooked up to yours would let you test your switch out until you can get a new battery. there may be a relay in the circuit thats gone bad and not working. you didn't hook up your jumper cables backwards did you and fry something.
Mike M
04-26-2006 12:17:11
Since you brought up the model F725 I have one with a 54" deck I bought used. Does yours have a filler piece in the front left corner so it matches the curve of the blade path instead of the weird shaped deck corner ? Mine is open in there. Crap blows out of that corner bad and up onto the top of the deck. I looked at one on a newer 455 at the dealer today and it had a filler in there. I don't know if they bolt in or weld in.
gene leonard
04-26-2006 12:23:51
 Re: F725 mower deck in reply to Mike M, 04-26-2006 12:17:11
i'll have to look but l believe its curved to the blade path, nothing is bolted in so it must be welded or part of the deck.
Mike M
04-26-2006 12:38:01
 Re: F725 mower deck in reply to gene leonard, 04-26-2006 12:23:51
Sounds like I'm going to have to make something up and weld it in there.
Glen in TX
04-26-2006 11:43:27
If battery is dead and it has electric clutch to engage mower you have to have enough power to keep clutch engaged. It's like the electric clutch on your auto air conditioning compressor. No power it won't engage or stay engaged.
gene leonard
04-26-2006 11:50:04
 Re: F725 mower deck in reply to Glen in TX, 04-26-2006 11:43:27
thanks
