4010 D
MN Bob
04-26-2006 04:46:12
Wondering is any of you know about what the 4010 Deisel uses per hour of work? I dont have a meter on the pump. I know its a 34 gallon tank and I cultivated 30 acres yesterday running in 5th at about 1600 rpm and still have a 1/4 tank showing. I have heard people mention a gal per hour and just wondered?? This was rebuilt a couple years ago and was told it was upgraded to 4020 engine. I know it uses the 4020 fuel filter. Oil level never drops more than 1/2 way to add between changes. Thanks, Bob
jd40an
04-26-2006 05:39:29
 Re: 4010 D in reply to MN Bob, 04-26-2006 04:46:12
I bought a used 4010D in Dec of '67,& still have it. After updating it to "4020" style(404CID) sleeves& pistons, with the pump "turned up" a little, it would produce about 90 HP, & use approximatly 6 gal per hr. under full load, but ,of course, much less when doing "light work". About 25 or so years ago I installed an M&W turbosharger along with the big aluminum oil pan & the seven bladed fan & M&W shroud(to keep the oil cooler). After this modification, the 4010, without changing the pump setting, produced 110hp, but surprisingly dropped 1/2 gal per hr in fuel to 5 1/2 gal under full load. I'll add, I didn't try to pull bigger implements but the same only much easier, or in a few instances one gear faster. On light loads this tractor is VERY fuel efficient, for instance while spraying at 1500RPM in 6th it will burn only 3/4 gal per hr. Planting with an 8 row planter at the same speed uses 1 gal per hr. With the turbo, this is easily the most fuel efficient tractor I've ever owned. I have well over 4000hrs. on it with this set up & it still runs as new. (The tractor has about 11000 total hrs).
MN Bob
04-26-2006 18:54:33
 Re: 4010 D in reply to jd40an, 04-26-2006 05:39:29
Thanks, Sounds interesting how you have upgraded the tractor. I have been happy with mine and I may just add a meter to check the use. Bob
