4320 Fuel Gauge Flutter
Dean Barker
10-27-2003 21:49:47
Does anyone know how to fix fuel gauge flutter on my 4320. It flutters badly anywhere between full and empty. Seems to be accurate otherwise.
G-MAN
10-28-2003 08:00:13
 Re: 4320 Fuel Gauge Flutter in reply to Dean Barker, 10-27-2003 21:49:47
It could be a bare wire, faulty gauge or faulty sender. I'd remove the sender first (make sure the fuel level is below the sender hole), and use an ohm-meter to check resistance through it throughout it's full range of motion. The resistance should change smoothly as the float is moved, with no big gaps or skips. You could also check the continuity through the wire, as it may have a bare spot that is leading to a short to ground. Power travels through the gauge, then to the sender and ultimately to ground, so it it's grounding before it gets to the sender, it will make the gauge act screwy. You can also take the gauge to your dealer and have them check it with their gauge-testing set-up. One of those things is bound to be the problem.
Dean Barker
10-29-2003 18:56:59
 Re: Re: 4320 Fuel Gauge Flutter in reply to G-MAN, 10-28-2003 08:00:13
Thanks G-MAN
