JD 4410 blowing fuses
Mopardan
04-25-2006 23:25:23
My 2002 JD 4410 blows a fuse for "switched circuits" when I switch to 2 wh drive. It has the push button switch. It will run all day in 4x4. Wiring looks ok. I unpluged the solenoids on the hyd block underneath and it ran. Pluged um up and blew fuse (20amp). It appears to take hyd pressure to move a cylinder for 2 wh drive. Solenoid? Relay? Bad wire? HELP!!!!! !!!!!
MSM
04-26-2006 05:30:13
 Re: JD 4410 blowing fuses in reply to Mopardan, 04-25-2006 23:25:23
Fair possibility one of the magnets has shorted out on the switching solenoids.That tractor requires the solenoid to be energized to run in 2wd.The magnet unseats a check valve.
