720D Camshaft Rebuilt
Kevin L.
04-25-2006 11:25:04
what kind of success has anyone had with getting a camshaft welding and the wooddrift key recut into the camshaft. Also need one of the injector pump lobe, minor dent, welding up and reground. Have trouble think about taking the temper out of the camshaft, then welding and retempering, what keeps the camshaft from benting and changing how it runs true without regrinding the bearing surfaces, which mean new cam bearing. any sugestion on someone to do this also.
skip 33652
04-25-2006 18:17:13
 Re: 720D Camshaft Rebuilt in reply to Kevin L., 04-25-2006 11:25:04
yalk to Albert at renassance tractor. in washington. he can tell you if it can be rebuilt or not. cam rebuilders can weld up lobes and straiten cams if they want to they can also rgrind them right if they want to.the cam I had reground going through albert was right on the money when i went to check cam timing. I got one for an 80 through someone else a few years back when i checked the timing on it and compared #1 and #2 was way out.Paul
