DEERE 70 GAS VALUE ?ssss
TIMAR
04-25-2006 08:34:11
My brother-in-law found his dads 70 gas which he bought brand new. Pretty rough and it needs a crank, flywheel and clutch disc driver. I found all of the parts for $650. The guy wants $900 for the tractor because it has like-new tires on the back. The hood is pretty bad also. I think If I could find a donor 70 or early 720 might be a better option. Opinions???
What are restored 70"s bringing in your neck of the woods?
JDBert
04-26-2006 06:34:06
 Re: DEERE 70 GAS VALUE ?ssss in reply to TIMAR, 04-25-2006 08:34:11
Timar- I agree with everybody else- ITS his dads tractor and there is no $ value!!! $900 with like new tires probably isn't too bad- New (lets just say 15.5x38's) would run you about $800. Its spendy to build one from the ground up! BUT you dont have to do it ALL at once, spread it out a little helps abunch. I'm doing one right now that probably isn't to far off of what your starting with- only mine was free and had no rear tires. I also got some parts from Mark2 ohio and he's great to deal with.
Josh in Indiana
04-25-2006 19:29:36
Maark has it right, you can"t put a price on dad"s tractor.
Maark
04-25-2006 14:13:56
If it was the tractor his Dad bought new, cost shouldn't be an issue.It is worth more as sentimental value as to what it would ever sell for.BUY IT NOW!
DickD
04-25-2006 14:38:27
 Re: DEERE 70 GAS VALUE ?ssss in reply to Maark, 04-25-2006 14:13:56
Right on Maark!!
Mark2 in Ohio
04-25-2006 09:11:06
Hi, where are you located? I have a donor JD 70 gas tractor and/or parts for you. I have a nice hood and clutch, flywheel etc. I am located in Ohio.
email is: [email protected]
