Brought home a '55 Model 60 over the weekend
Rockbasss
04-24-2006 23:10:53
third party image
The price was right so now I have to get it running. The 60 sat for about 12 years outside. When it was parked the owner said it only had about 15 hours on a total rebuild/restoration. The clutch is stuck, motor was stuck until I gave it a little pull. He had some sort of monkey juice in it all along and the stack covered to keep it loose. Vandals took the gas cap so the gas tank, carburetor and anything with the fuel system needs to be check/cleaned. The wiring looks like a mess. Roll-o-matic front. The rear tires are loaded and one is leaking at the valve stem so I need to address that ASAP. The breaks work good. Sure needed them when loading and unloading. The grill has some dents that should be able to work out and the sheet metal has some minor dent that should smooth out. The rear tires are loaded and one is leaking at the valve stem so I need to address that ASAP. I was informed that there is a problem with the PTO over heating when it was last used. He thinks that something is shimmed to tight. He doesn't think the seals are bad, said their wasn't any oil mix when he drained it.
Fred from MO
04-25-2006 19:05:37
 Re: Brought home a '55 Model 60 over the weekend in reply to Rockbasss, 04-24-2006 23:10:53
Lookslike yours was in better shape than mine. I learned a lot about the 60 from people on this site. If you have any questions just post them and maybe I can help you out.
Fred
wayray
04-25-2006 03:53:37
Go to www.mrbtractors.com to see the picture of a john deere 60 Tyler Buchheit has just restored, she is a beauty. Your's has the same potential. Good Luck!
