How Do I Start a JD S92 Riding Lawn Mower?
Linda in MO
04-24-2006 21:48:04
My husband passed away last year so I've decided to sell our mower. I don't want to buy a manual, since I'm selling it. I just need to know the starting procedure, so I can show that it does run.
BTW, anyone have any idea what I should ask for it? We bought it, used, in 2000, for almost $600 but used it very little ourselves. It's in good condition.
I hope someone can help me. Maybe by emailing a copy of the manual page that has the info I need.
Thanks....ringer
Maark
04-25-2006 14:10:58
 Re: How Do I Start a JD S92 Riding Lawn Mower? in reply to Linda in MO, 04-24-2006 21:48:04
Make sure the transmission is in neutral, pto lever[yellow knob] on steering column is pulled back towards you, throttle in the choke position[red maybe black knob all the way forward, will show a turtle and rabbit on it] sitting on the seat push the clutch pedal all the way down.Gas in the tank and charged battery, Turn the ignition switch to start.
Linda in MO
04-25-2006 15:26:06
 Re: How Do I Start a JD S92 Riding Lawn Mower? in reply to Maark, 04-25-2006 14:10:58
Thank you so much, Maark. One more thing, does it use just regular gas....no oil and gas mixture?
Linda
Jim_WV
04-25-2006 17:41:35
 Re: How Do I Start a JD S92 Riding Lawn Mower? in reply to Linda in MO, 04-25-2006 15:26:06
Just regular gasoline Linda. In addition you should check the engine oil to make sure it is full. Look at the engine and locate the dipstick, it should have a yellow round cap or black, may even say oil on the cap. Pull it out, wipe it with a paper towel and re-insert, then pull back out and see where the oil is on the diptstick. Running the engine too low or without oil will destroy it.
