JD 535 Won't start a core
Curt H
04-24-2006 17:35:10
I have a John Deere 535 baler. When you go to start a bale the crop feeds in but then plugs the pick up. If you look inside you can see that the belts don't seem to be rolling the crop. Especially bad when dry. Theb belts don't look to be in to bad shape.
txfarmer84
04-26-2006 09:06:10
 Re: JD 535 Won't start a core in reply to Curt H, 04-24-2006 17:35:10
We had the same problem with our New Holland Baler last year. I know its not JD, but we had good luck when the grass was just a little bit damp like from the morning dew. Our hay was short and dry so all this added up and caused problems. I dont know how dry your hay is, but thats my experience. Kyle
430WLPG
04-25-2006 18:37:44
Right on about welding a thin flat bar to square up the leading edge of the starting roller
Roger in Iowa
04-25-2006 07:43:36
The belts have three little steps in the pattern. Look at a new belt and you can see. If you are well down into the second or into the third, you need to replace belts. They are not aggressive enought to start the core.
Other comments about pickup are true also!
Roger in Iowa
Tx Jim
04-25-2006 03:56:48
Curt,are all your pick-up teeth there? Is PU belt slipping? Are you running pick-up just low enough to get hay? When trying to start a bale use slow rpm's. You can aid starting problems by welding on leading edge of flat bars on metal starter as these bars get rounded off from use. What type hay are you baling? JD offers a soft core attachment. I tried one years ago but went back to original on next baler. Tx Jim
