JD 317 Deck bearing replacement
cardr01
04-24-2006 14:20:13
All,
I'm trying to replace my bearings on the deck of my 317. I got the spindles out of the deck but can't get the pulley's off. What's the best way to do this? Also, once I get the pulley's off how do the bearings come out?
Thanks for the help,
Doug
Maark
04-25-2006 00:50:06
 Re: JD 317 Deck bearing replacement in reply to cardr01, 04-24-2006 14:20:13
There is a snap ring at the bottom of the spindle housing. It will need to be removed before the lower bearing will come out. The top will come out by reaching through the bottom bearing and knocking it out with a punch.
Bob
04-24-2006 15:20:27
Do you have the nuts removed from the pulley end of the spindle?
If the pulleys are rusted in place, and you want to save them, support the bearing housing casting, and press the spindle down, out of the complete assembly. Penetrating oil is always good, too!
This will shear the woodruff key that keys the pulley to the shaft, as once the shaft moves downward, the key will be pressed against the bearing, which has no slot for the key, so it will simply shear off.
The key, # 26H14 is about $.24, a LOT cheaper than buying a new pulley.
cardr01
04-25-2006 12:25:50
 Re: JD 317 Deck bearing replacement in reply to Bob, 04-24-2006 15:20:27
Thanks guys for the reply. I'm in the middle of it now and will let you know how it goes.
The top bearing near the pulley just fell out, and the new one slid in w/o being pressed in. I hope that's OK. When I pressed the spindle in it holds the bearing in so I guess that will work.
Thanks,
Doug
