3020 Overheating
Gary Cobb
04-24-2006 07:38:24
Recently purchased a 3020 gas. After running a short time the temp gauge reads hot. The bottom radiator hose is cool which leaves me to believe the thermosat is stuck closed. This tractor was shedded and not run the last couple of years so I"m hoping that"s the problem. Also the temp gauge"s needle stays in the middle of the gauge even when the engine is cold. Should I replace the gauge and if so where can I get one? Thanks!
Jim Burns
04-24-2006 15:44:56
 Re: 3020 Overheating in reply to Gary Cobb, 04-24-2006 07:38:24
If your temp gauge starts off in the middle, and goes to hot after it has been running, could it be that the gauge is indicating an incorrect (eg. higher) temp?
daryl in ontario
04-24-2006 08:14:13
as for the temp guage any john deere dealer or equivalent store should be able to order you one
i hope its only your thermostat but i would remove it altogether and see if the water flows via that it maybe your water pump ?
