2010 remote hydraulics
Dave / Believer
04-23-2006 18:53:14
I have a 1964 2010 with remote hydraulics. I want to eliminate the remote hydraulics control valve (it has a couple issues and I do not need the remote). The bypass kit is no longer available and I have not been able to run one down in the salvage yards. If I remove the valve body from the pedestal it bolts to there are two hydraulic oil ports. I either need to make a path to let the oil circulate from port to port or I can block off both ports. Can anyone tell me which I need to do?
Thanks -- Dave / Believer45
Dave / Believer45
04-23-2006 19:30:37
 Re: 2010 remote hydraulics in reply to Dave / Believer45, 04-23-2006 18:53:14
I have the valve off already, the spool is damaged and I cannot find a new one. The valve body seems OK. If I can just make a high pressure hose loop and tap the two ports in the valve pedestal that would make the "flow through" I need. Thanks MSB and Bob for your replies.
If anyone can tell me a different way to do this I would appreciate it. Sometimes my ideas get a little out there instead of just outside the box.
Dave / Believer45
msb
04-23-2006 19:17:58
The by pass valve in the valve itself should eliminate the valve from the system.Sounds like that is where the problem is.That valve isn't that complicated to repair or rebuild.Getting the valve out is a bigger problem that the repair itself.
msb
04-23-2006 19:25:56
 Re: 2010 remote hydraulics in reply to msb, 04-23-2006 19:17:58
Meant to add.You may be able to get the by pass valve working (if it is only sticking) by hooking up a remote cylinder and quickly operating the remote back and forth in both directions for a while.Do this at fast idle.
Bob
04-23-2006 18:57:51
The 2010 has OPEN CENTER hydraulics, so the flow cannot be simply blocked off. It will need to be looped over the other line. There MAY be more to it than that, also. It's been a LONG time since I've been in the hydraulics of one of those.
Bob
04-23-2006 18:57:34
Tx Jim
04-24-2006 04:27:17
 Re: 2010 remote hydraulics in reply to Bob, 04-23-2006 18:57:34
Bob,you are correct if blocked off rockshaft wouldn't work and pump would be cracked would be my guess. Tx Jim
