Chris, Bleed Green is correct. The lil wire from the starter switch to the coil or coil side of the Ballast IS SUPPOSED TO BE HOT ONLY WHEN CRANKING. Take a test lamp or voltmeter and place it on the high (from ignition switch NOT to coil) side of the Ballast Resistor, turn the ignition switch on, and battery voltage ought to appear there to light the lamp. If not, I suspect a bad ignition switch or the wire from it to the ballast is open or else the switch has no BAT input voltage. Do the lights work??? meaning the switch does indeed have battery input voltage so thats not the problem. If the light works on the Ballast Input when the ignition is on and near battery voltage appears there (means ignition switch and wiring are okay) place the lamp or voltmeter over on the other (to coil) side of the Ballast and the voltage there (if points etc. okay and closed) ought to be around 6 volts and the lamp glow but not as bright. IF THERES NO VOLTAGE ON THE LOW (TO COIL) SIDE OF THE BALLAST, ITS BAD/OPEN. The Ballast Resistor if good ought to measure around 1.5 to 1.85 ohms across ts terminals, if its an open circuit, its bad the wirewound resistor is likely burned open. Another test would be to temporarily jump a "hot wire" to the coil n see if it runs then (just do a short time), and if so the problem is the switch or ballast or wiring like Bleed Green told ya. If it does run, then next try to hot wire to the input (from switch NOT to coil) side of the ballast n see if she runs then. If NOT, the Ballast is likely bad/open. If so, the ballast IS NOT THE PROBLEM (current is flowign through it) so the cause must be the switch or the wire from the switch to the ballast. Let us know what you find John T
