2040 remote control
machinery-man
04-23-2006 05:49:26
Would anyone know a good place to find remote control setup for my 2040. Naturally want a reasonable price. I think the 1020 is the same but not absolutely sure. Any advise appreciated.
billde
04-23-2006 13:15:42
 Re: 2040 remote control in reply to machinery-man, 04-23-2006 05:49:26
according to my manuals anything after serial 350,000 is closed center. The parts manual however lists both types of pump.
Tx Jim
04-23-2006 07:30:56
Machinery man,early JD 2040's are open-center hyd's,later ones are closed-center. All JD 1020's are closed-center. If your tractor has a piston pump it's closed-center and if a gear pump it's open-center. If it's open-center a SCV off of a JD 820/830 3 cylinder should work. HTH,Tx Jim
machinery-man
04-23-2006 09:51:57
 Re: 2040 remote control in reply to Tx Jim, 04-23-2006 07:30:56
Mine is a 1980 model...manhiem.....
Tx Jim
04-23-2006 10:14:10
 Re: 2040 remote control in reply to machinery-man, 04-23-2006 09:51:57
All JD 2040"s were built in Manhiem. If I remember correctly an "80 model is closed-center. Does it have a small,two compartment gear pump or the larger pump with pistons? Tx Jim
