'49 A connecting rod journals
Rutland
04-23-2006 05:16:09
Do you think it would be a good idea to use a strip of crocus cloth to polish the connecting rod journals on the crankshaft to get rid of any slight ridges that may be there before I try to 'mike' the journals?
Rutland
04-24-2006 05:45:44
 Re: '49 A connecting rod journals in reply to Rutland, 04-23-2006 05:16:09
Thanks gents. Tim
Rutland
04-24-2006 02:55:04
Frank, There's bound to be a small amount of debris that will get into the oil holes in the journals, do you think that this will have any significant effect on things once the oil starts flowing back back out on re-start? Tim
F-I-T
04-24-2006 05:09:39
 Re: '49 A connecting rod journals in reply to Rutland, 04-24-2006 02:55:04
Rut:
I would probably drag out what I could with a Q-tip dabbed in some clean grease, and forget about the balance. You could give it a spin, but you have to have oil around the pump.
I guess if I was really worried about it I would squirt a half ounce of diesel fuel down the hole on the #1 journal, then blow it out the # two hole by applying my rubber tipped air gun to the #1 hole (cover loosely with a rag and close your eyes...), then repeat for the other side going in the other direction.
Won't be no dirt worth mentioning then.
Frank
Mike M
04-24-2006 06:05:12
 Re: '49 A connecting rod journals in reply to F-I-T, 04-24-2006 05:09:39
#1 and # 2 rod oil gallies are not connected. They are feed from each main.
F-I-T
04-24-2006 12:03:54
 Re: '49 A connecting rod journals in reply to Mike M, 04-24-2006 06:05:12
Ok. Then shoot a stream your favorite pressurized Wd-40 type "stuff" down in the hole and let the crud back wash out.
Mike M
04-24-2006 04:36:43
You can always spin it without the rods attached and let the oil pump flow some oil through there first. Run a small passage brush in the holes too.
F-I-T
04-23-2006 07:51:20
Rutland:
It will not hurt at all. You can actually use pretty aggressive cloth backed 240 SC as long as you finish with some greased 600 to give it a final polish. If you use lay out dye, you'll be able to see when you get close to smooth.
Now the engine builders will tell you that you should polish so as to lay the steel down so the feather edges trail the rotation direction of the shaft, so they don't add unnecessary wear to the bearing surface.
Frank
