4020 hydraulics not working
Roger in Iowa
04-22-2006 18:59:13
A friends 4020 (late) hydraulics quit working because he ran low or out of trans/hydraulic oil. Refilled and three point does not work. Steering does not seem to have much power. I have not seen or tried anything. He did change filter after incurring the problem but no help.
Is there an air lock or bubble? Do we need to bleed something? Is the priority valve stuck? Any ideas?
Sorry for not having more information.
Any ideas??
Thanks,
Roger in Iowa
Weldrunner
06-22-2006 09:24:48
 Re: 4020 hydraulics not working in reply to Roger in Iowa, 04-22-2006 18:59:13
Roger, I had the same problem on a friends 4020. they ran the oil low. I remove the cover around the steering sector, located the main line comming from pump. (should be on top rt. side just under the cover)I had the tractor running and very carefully loosened the fitting at what looked like a valve and let the air out and the pump picked up and started working. It was just air locked. Oh, I went to the local JD dealer, talked to the machanic....didn't help a bit. I also cleaned the screen and changed the filters first, that didn't work.
onefarmer
04-23-2006 18:52:09
Check the pickup screen. It could be plugged.
430WLPG
04-23-2006 14:40:21
Probably has not picked up the oil. This may not work, but it's worth a shot.Take the trans oil filler cap off and take your air compressor and a blow gun with a rag wrapped around it for a seal and start tractor and then blow air in for a minute or so do it a couple of times it may do it for you.
