Mace: >>My power trol is leaking down rather quickly, almost instantly with a load. If the cylinder/basic housing gasket leaks, then how does this cause the rock shaft to leak down? As was said, the oil enters via a gasketted port on the open mounting end opposite the blind end of the of the cylinder. If the gasket fails around this port, the pressurized oil escapes and the lift falls fast. >>Wouldn't this be a check valve problem/leak? Not necessarily. There is a test for this to rule out cylinder versus Powr-Trol box, but you might want to find a book that describes the items. Even an operators manual will be helpful. >>I'm confused. I would agree that that might be the case. >>What holds the implement up? Is it fluid against a check valve? Yes, it is, but again if the check valve is working but the trapped oil is escaping out of a gaping hole in the cylinder gasket it's the same as no check valve at all. >>When the rock shaft is in the up position against spring pressure, where is all of the hydrolic pressure located? Not sure what you mean about the "spring pressure" as lift drops by gravity, depending on the weight of the implement to get it to fall. Oil pressure lifts it up. The oil is trapped between the valve box, which contains both the selector valve that is operated by the "raise and lower" handle, and the check valves. >> Is it on top of or below the piston? The oil is trapped between the top of the piston and the blind end of the cylinder. >>If the piston seals are replaced and the cylinder gasket replaced and a the 3 point is still leaking down with no visible leaks present then where should one go to look next? Now we get to the heart of the matter. With an implement or a hitch that is heavy enough to cause the rockshaft to sink after the load is raised and the lever is returned to neutral, locate both the throttle valve and the metering valve, which are located under 1" or so tall, 1/2" hex cap nuts. Note how far you turn these valves so you can return them to their original position. Now, turning them CCW will move them outward and up against their seats, so "out" is "closed". Once closed, the Powr-Trol box is eliminated from the circuit, because the oil is mechanically trapped in there. If the load still falls, the problem is on the inside of the rear end, i.e. the cylinder gasket/piston ring/ or an internal crack that is allowing the oil to leak out. If the hitch stays up, then the problem is located inside the Powr-Trol box. By now you should have determined if you are losing oil as well as having a lift that won't stay up, becuae if the gasket if faulty, the oil leaks out in to the rear end, which causes the gear oil level to rise. Note: 99% of the time it is the cylinder side. This is often verifed, sadly, by folks who are prematurely convinced that it can't be that simple on their tractor, and so commence to disassemble the P-trol box anyway, along the way creating a loose source of parts for all of us in need as they almost never get it back together, and have to purchase an operating unit from a salvage dealer. Count on something in your previous cylinder repair being the culprit, but you should test for it just the same. Frank
