1010 jd where can i find a reasonable price overha
frank allen
04-21-2006 16:39:16
i need the parts to rebuild my 1010. cant seem to find them,john deere parts are way to expensive
55 50
04-22-2006 10:31:28
 Re: 1010 jd where can i find a reasonable price ov in reply to frank allen, 04-21-2006 16:39:16
I agree with buickanddeere. Be happy you can still get them from Deere rather than having to search all over God's creation to find something else that may or may not work! The fact that Deere continues to make parts for the old stuff, makes their old equipment stay high in price and the parts stay high in price. Ever try to maintain an inventory of parts whose quantities are slowing dropping as old equipment becomes obsolete or completely worn out? It provides less and less quantity to spread your costs over, thus each piece's cost has to increase. That will make you a believer very quickly as to why the prices are high.
jdemaris
04-22-2006 07:12:13
Depends on if it's gas or diesel, and what age. Early 1010/2010 engines are different from later - especially the main bearings. Also, a diesel 1010 uses the same sleeve deck as a gas 2010, and if that's what you have, oversize pistons can be an option. It also means you can expand your search to 2010 parts for the 1010 engine. Also, if the piston skirts and pins are okay, you can regroove the piston grooves much cheaper than buying new pistons. Main cost issue is the sleeve deck - and to my knowledge - no aftermarket decks have ever been available - they only come from Deere.
buickanddeere
04-22-2006 05:47:08
At least you can still get new dealer parts for an obsolete 33+ year old peice of equipment. Try that at the other dealerships, that is if they are still in business.
buickanddeere
04-23-2006 14:47:52
 Re: 1010 jd where can i find a reasonable price ov in reply to buickanddeere, 04-22-2006 05:47:08
43 plus years
lloyd in sc
04-21-2006 21:50:21
Just keep surfing ebay they do come up fairly often.
hank n tx
04-21-2006 18:23:16
go to the TISCO web sight and find a dealer close to you. they may have them.
