410 backhoe hydraulic PSI loader control valve
Mike Grodecki
04-21-2006 07:50:16
HI: I have a John Deere 410 backhoe,I think It's a 74,It has drag links no steering cylinders.Where do I check the hydraulic psi and adjust it from?Is it the pump stroke valve on the pump that adjusts the system psi?It keeps blowing the loader control valve O-rings on the side of trany,It must be set to high.Any other sugestions,maybe a relief valve not working?Thanks for any help!!! MIKE
Roy Suomi
04-21-2006 20:02:30
 Re: 410 backhoe hydraulic PSI loader control va in reply to Mike Grodecki, 04-21-2006 07:50:16
If it hasn't been screwed with ,it probably needs a new pressure control valve housing.. You can check stand-by pressure at the hydraulic pump.Small port on the starter side of the hydraulic pump. If there's 2 plugs, it's the top one for stand-by pressure test port..Should read approx 2300 psi without touching any functions at just above idle speed.. Are you torqueing the pressure control valve bolts with a torque wrench?? 35 ft lbs.....If they're not torqued evenly , the o-ring will blow...proven fact...Deere used to supply a nylon o-ring [white in color ]..they lasted a bit better than standard black o-ring..I don't know if they are still available , but it might not hurt to find out..Or try to find one aftermarket from a hydraulic supplier
mike grodecki
04-22-2006 05:59:11
 Re: 410 backhoe hydraulic PSI loader control va in reply to Roy Suomi, 04-21-2006 20:02:30
OOOPPPPS Reply,just had to correct that!
MIKE Grodecki
04-22-2006 04:45:44
Roy: thanks for your replie.I had to install a new loader control housing,When I bought the machine it was leaking from the housing not the O-ring pouris holes in the housing,what I thought was a fitting leak,so I installed a new housing.I'll try torqueing them, I didn't do that.Sounds like a good Idea!And NO I don't have a service manual on the machine,I have 1 for a 510 but not 410 differant machines 410 is old and has drag links.machine runs good and has lots of power.Seems strange the way it moves with the moving of the hydraulics. Thanks MIKE
