410 backhoe moves slow
Mike Grodecki
04-21-2006 05:22:53
HI: I have a John Deere 410 backhoe,I think It's a 74,It has drag links no steering cylinders.The problem I'm having is it has no power moving.I't has a hard time going up slight grades and pushing,but when using the hydraulics front bucket while moving forward power comes back but stop when not using it.I crawled under it to look at the linkage on the reverser valve,every thing is moving but sloppy.Could there be to much play in the linkage not letting the valve open all the way?clutch seems to grab good. Thanks for any HELP MIKE GRODECKI
Roy Suomi
04-21-2006 20:33:29
 Re: 410 backhoe moves slow in reply to Mike Grodecki, 04-21-2006 05:22:53
Holy Smokes....You got a lotta problems with one machine....Lemme get this straight.. Trans seems to slip when not using hydraulics?? But pulls fine when you pull back on the loader control lever..That doesn't make sense.. The hydraulics are run from transmission charge pressure..The trans pump powers the transmission first , then pumps oil to the hydraulic pump.Put a gauge into the reverser control valve to see whats it's making..Should be approx, 135 lbs [ gearshift in neutral , reverser lever in forward ] at half engine speed. Run the engine speed from dead idle to wide open throttle..Is there a wide pressure reading?? If so the filter relief valve has some crap in it...I hope I shed some light on this problem. Maybe someone else can shed some light on this problem child..It's tough to troubleshoot a problem without being there and actually running the machine..It might be something very simple or a tear-down.. If you have a service manual , it will walk you in the right direction. Most people look in the book and get weak knee'd from all the diagnostic steps...Do the transmission pressure tests first...Good Luck
Mike grodecki
05-04-2006 15:35:03
 Re: 410 backhoe moves slow in reply to Roy Suomi, 04-21-2006 20:33:29
Hi: I finialy found some one with a set of gauges.We did the psi test.Hydraulic pump stand by psi 2700.Is 400 over to much to blow seals?Ok now the reverser valve psi 60-70 with trany in neutral reverser valve in forward at an idle full throttle dosent change anything.moving the reverser valve from forward to reverse make the psi drop off but then it come back.Depressing the clutch pedal also makes it drop off.Moving the hydraulics dosent change it.Where is the trany relief valve located? where is the trany screen located? Any Idea's Maybe relief valve stuck open not building enough psi? Thank's for any Help MIKE
