4440 Air Filter Indicator Lamp
unlkid
04-20-2006 21:38:31
Should the air filter warning light glow when the ignition switch is in the "on" position? When the switch is in the "start" position? The transmission oil warning light glows when the switch is in the "on" position. The air filter warning bulb is ok. If the air filter warning circuit is not working correctly, what is the most likely problem? Where is the connector that energizes the instrument panel circuit board?
WTW
04-21-2006 06:33:57
 Re: 4440 Air Filter Indicator Lamp in reply to unlkid, 04-20-2006 21:38:31
The Air filter indicator will "not" normally glow with key switch in the "ON" position unless there is a filter restriction. To check air filter indicator bulb, with engine "OFF" put tractor transmission in gear and turn key to "START" position as if you were going to crank engine to start it. Engine should not crank because neutral start switch should be open with transmission in gear, not allowing current to starter circuit. With key in "START" position air filter indicator should glow telling you that bulb and circuit to it is working. To check remaining circuit to filter restriction sensor simply leave key in "ON position, engine OFF and ground sensor wire at sensors, bulb should glow. To check sensor itself remove it, plug wire onto it, ground body of sensor and apply a small vacuum to it, bulb should light. It does not take much vacuum to activate sensor switch, as I have sucked on it to make it activate and it works. Good Luck, DW
