1935- B
Mike in Wi.
04-20-2006 18:37:06
Just bought a 1935 John Deere B.The tractor idles great but when I give it the gas it almost dies out-- no power.I played with the carb.adjustment but to no avail.Any ideas?THANKS
Kris in NY
04-22-2006 18:20:37
 Re: 1935- B in reply to Mike in Wi. , 04-20-2006 18:37:06
Hi Mike, John T's response looks pretty thorough to me, but I can add a little to it. I have a '37 B and I recently had a similar problem. I just bought the tractor last fall after it sat in a barn for years. There was quite a bit of debris that had worked into the valve at the bottom of the fuel tank, which slowed gas flow from the tank into the glass bowl down quite a bit. When I tried to throttle up, there just wasn't enough flow to keep it going. I cleaned out the tank the best I could, and reamed out the valve opening from the gas fill cap with a long chain-saw blade sharpener. Gas flows great now.
John T
04-20-2006 19:04:49
Mike, if she has fresh clean water free gas and the needle adjustments dont help, my first guesses are the float level is too low or the main center vertical nozzle is clogged up. The carb also has to be getting sufficient gas flow out of the sediment bowl and any 3 way valve etc and into its side inlet strainer and then through the needle valve n seat, the needle n seat area might be clogged or has gum n varnish also.
Turn the gas on and open the carb bowls lower drain cock plug and a steady stream of gas around 1/16 inch ought to flow continuously out or else theres a restriction in the needle n seat or the carbs side inlet strainer or upstream out of the tank or through the sediment bowl and/or 3 way valve, insure the 3 way valve is set for full flow out of whichever tank youre on.
If you remove the gas line from the carb and turn the gas on, a steady stream the size of the lines ID ought to flow continuous if the tank outlet and sediment bowl and any 3 way valves are set right n clean n free.
If theres good flow to the carb but NOT the good flow out the bowl bottom drain cock plug as described above, the carbs side inlet strainer may be clogged up. Maybe remove the side pipe plug drain n use gumout to clean it out and/or remove the top nut n cap to clean out the strainer and the needle n seat at the bottom with gumout. If theres good flow to the carb and the strainer is clean but still poor flow out the bowls bottom drain, then I suspect the needle n seat may be clogged up.
If theres good flow to the carb and she runs out the bottom drain as described and needle adjustments dont help, then Im back to the float levels too low or the center nozzle is clogged up.
An ignition problem could also be a contributing cause, try new plugs and check the points gap and make sure the points arent burned or pitted or carboned badly n replace if so and check for a good visible blue instead of any light wimpy yellow spark at both plugs.
John T
