1951 MC Stuck steering clutches
thehickdaddy
04-20-2006 01:10:50
hello there. well, someone finally left grandpas 1951 MC outside too long without running it and BOTH steering clutches stuck. what is the proceedure to remove the final drives and free or replace the clutches? do i have to break the tracks or can i lift off one whole side with the forklift? if the job goes smoothly the neighbor has a 40C with the same problem that he would like me to fix for him. these tractors are mechanically identical, right? both of these tractors are in origianl condition and are still in light use, and i dont mind working on them. thanks for any help. i do not have any books.
thehickdaddy
Mike M
04-20-2006 08:18:24
 Re: 1951 MC Stuck steering clutches in reply to thehickdaddy, 04-20-2006 01:10:50
If they were working fine before and just stuck from moisture to the plate I think I'd try other ways before pulling it all apart. Can you look in there and see the disk ? Block the handles back and try to lightly pry the disk away from where it is stuck. I was able to do this to the engine clutch of a 3010 JD Or take it out and push on some tree stumps with the levers blocked back and see if they pop loose.
CH
04-20-2006 03:00:48
You have to split the track but on a MC/40 It is not bad,find the master it should have a clip on it and losen tracks a bit and drive master out . I try to get it on the spocket so something is holding it.After track splits take fender off,then all the bolts around final Don't forget the two under and the draw bar bolts. If you need parts email me for my link i sell each piece and i have a complete kit.
