Carb. repair 101
Mike M
04-19-2006 19:18:22
Just a reminder to anyone working on a 2 cyl. carb. with those brass passage plugs. It is of the utmost importance that these plugs have some fuel resistant sealer (like permatex non hardening)applied to them and then tighten them up tight. Just got done solving a problem a local tractor repairer had with a JD H . The idle would never settle in it keep changing around you try to adjust it and it would change. Well it turns out this carb. was previously sent off to a well known rebuilder (starts with B )and it looks like they don't make a standard practice of sealing these plugs. What a nightmare this has caused this fellow.
Bob-Wyo
04-20-2006 08:15:20
 Re: Carb. repair 101 in reply to Mike M, 04-19-2006 19:18:22
Mike I had the same drive you nuts problem with a #16 D carb, only way I found it was rig up a plug for the upper part of the well and apply air to the bottom with the nozzle removed, a little soap showed the upper plug leaking by the threads on one side. A new correct plug still leaked so had to seal with locktite, been working good for over 7 or 8 years now.
I like Glen never used a sealer with no problems but after this, think I will again follow Duane's advice for a little insurance. (Now just maybe that's the problem with this stubone starting 36 D I'm working on),or maybe the 1/4 turn start 38 D has me spoiled. LOL Bob
Glen in TX
04-19-2006 19:48:08
That's a new one on me and never caused me a carb problem or leak yet. I think too many are using taps the wrong size or getting the threads too loose on carb body or new plugs aren't the same. Or maybe ran a clean out drill too crooked or too big ruining plug hole ? The SM2024 never mentioned sealer but does caution that there are 3 sizes of plugs and they should be returned to the correct size holes. I would only use the sealer sparingly if needed since not using has worked fine for me for 30 years.
Mike M
04-20-2006 04:33:40
 Re: Carb. repair 101 in reply to Glen in TX, 04-19-2006 19:48:08
I'm sure you have and so has the other fellow gotten away with it for years. I myself never took a chance and have always put a little on them. And it looks like it has paid off for me. These castings are very old and may have some metal worn or erroded away. I also think that when the castings were new and the plugs too that Marvel Sheubler didn't need to use any either and it worked fine.
Glen in TX
04-20-2006 08:41:47
 Re: Carb. repair 101 in reply to Mike M, 04-20-2006 04:33:40
Mike, I got thinking about that more later and I probably have used some high tack sealer on a few new brass plugs that didn't fit to my liking. When I read that last night was probably envisioning someone using too much sealer that clogs the passageways worse. The threads are worn on many of the carb bodies. That's why I save a can of old plugs to reuse where one doesn't fit tight. Recall having one carb that had deep slotted cuts in carb body around a plug hole from someone trying to cut slots in plug with a dremel cutter to remove plug instead of heating it and I had to fill the slots in and rethread hole. Then another one came in with plugs JB welded in because they used the wrong size plugs. All those type of things are only going to get worse on these old carbs. Too bad the deal to make new carbs keeps falling through but if not made to quality standards will present more problems as well.
Duane Larson
04-19-2006 19:42:43
Mike,
Good Point! I've been using Locktite PST for years - also on the load and idle needle threads as they can degenerate and allow unmetered air. There's more than one "B" - this one from Illinois?
Mike M
04-20-2006 04:24:21
 Re: Carb. repair 101 in reply to Duane Larson, 04-19-2006 19:42:43
I don't know where their from ?
Starts with B ends with Y
