60 rear end milky oil
superfarmer
04-19-2006 18:42:24
I've got two 60's, and the gear oil in one of them keeps going milky, I would assume from condensation or something. Both have had new oil, but the other one is as black as can be. Any ideas? I've tried draining first reduction gear housing, but usually just get oil out. Also, what would be wrong with using used Hy-Gard hydraulic oil in the rear end? Not planning on going plowing or anything. Thanks.
Dave
Dairy Farmer
04-20-2006 16:46:58
 Re: 60 rear end milky oil in reply to superfarmer, 04-19-2006 18:42:24
Every time you park it outside, cover the shifter just in case it rains cuz i had that problem but when i covered the tower i had no more problems.
Don L C
04-19-2006 20:12:37
Check for other ways rain water can get in....usualy around bolts in the cover.....
Ron R.C.
04-19-2006 19:01:03
condensation seems to be the problem. I have 3 john deere"s and all of them will sweat when coming out of winter into the spring. I personally wouldn"t recommend using Hy-gard in the rear end as it is a real light oil. I have found that pulling the drain plug and letting the moisture out after winter and before they are run helps keep down expense on oil. Just my opinion.
Ron R.C.
04-19-2006 18:55:43
