1937 B Pulling first reduction gear
courtland
04-19-2006 08:49:35
I do have the first reduction gear exposed and ready to remove. Does it come off the splined shaft with a "gear puller" OR do I have to remove the wire tied bolts and seal first located on the main case?
I do not want to break the gear, of course...
WTW
04-19-2006 09:13:46
 Re: 1937 B Pulling first reduction gear in reply to courtland , 04-19-2006 08:49:35
First reduction gear is pulled up tight on tapered spleen of transmission drive shaft and you will need to pull gear loose from shaft with a puller. A word of caution when doing this is to block forcing screw of puller off spleened end shoulder of shaft over top of threaded end of shaft with a socket or bushing so you do not put force on the threaded end of shaft as force of puller will cause threaded end of shaft to break off. Have seen this happen more than once, don't know if it was the shock from striking the forcing screw under pressure or if it was due to previous over torquing of shaft nut that may have damaged shaft end. Just a simple precaution to protect the transmission shaft end. Good Luck, DW
courtland
04-19-2006 10:45:34
 Re: 1937 B Pulling first reduction gear in reply to WTW, 04-19-2006 09:13:46
thanks...just what I was in the process of doing, even protecting the threads.
