JD 40C Compression
Porub
04-19-2006 07:29:48
Could some one tell me what PSI the compression should be on a 2 cylinder model 40?
Thanks
jCarroll
04-19-2006 17:25:29
 Re: JD 40C Compression in reply to Porub, 04-19-2006 07:29:48
I'd say 100 - 120 is good.
85 - 100 means it will run OK
Take both plugs out, and have the throttle open when you take the readings.
Then squirt a teaspoon of oil in each cylinder and do it again. If compression goes up by 10 psi or more, your rings are in poor condition.
tstex
04-19-2006 15:08:34
Porub,
I was told 115psi...it was never in any of the deere service manuals, but in a deere service bulletin.
Check out the tune-up area of the YT "research and info" section. It gives a pretty nice overview of how to perform a good compression test for these 2 cylinders.
Good luck and post back to what your readings are when you finish. The greater the delta between 1&2, the more time we you be spending in your garage some day.
tstex
