4230 air conditioning and over heating
eldo
04-18-2006 20:36:22
My air conditioner quit(agian. One fan motor quit on the right, then, came back on, then compressor would not kick in( no spark to compressor), then left fan motor quit and right runs,. Any one got and Idea.
Also my tractor has 10,000+hours, new radiator and thermostats, but still runs to warm, Uses very little oil, is the water pump worn out or is there possibly something else that could cause this overheating.
Hot and tired of sweating.
Thanks, Arnold
lonzo
04-19-2006 02:33:01
 Re: 4230 air conditioning and over heating in reply to eldo, 04-18-2006 20:36:22
I have been finding that the fan pulley groves are worn so bad that the belts no longer hold causeing fan to not work good enough. Some times i wind up taking the radator all the way out so i can see threw it and find all kinds of weed fuzz and maybe oily stuff from where a oil cooler line had leaked at one time or the temp sender was lying to the gage giving wrong reading
Bob
04-18-2006 21:01:51
"My air conditioner quit(agian. One fan motor quit on the right, then, came back on, then compressor would not kick in( no spark to compressor), then left fan motor quit and right runs,. Any one got and Idea."
The 2 fan motors are connected (by the switch) in series for LOW, and both to 12-Volts for HIGH.
IIRC, the fan switch is fed from 2 circuit breakers in the steering console, by your left shin. One may be tripping, taking the power to the AC compressor clutch with it.
Possible causes of your problem...
1.) Weak circuit breaker or connections on breaker need tightening.
2.) One bad fan motor, or a bad AC clutch.
3.) A short in the wiring under the cab, to the harness connector, where the harness goes up the cab post, or foward to the compressor clutch.
4.) Bad fan switch (which also supplies power to the AC thermostat).
"Also my tractor has 10,000+hours, new radiator and thermostats, but still runs to warm, Uses very little oil, is the water pump worn out or is there possibly something else that could cause this overheating."
How hot is it getting... could it just be a gauge or sender error?
Have you checked and/or replaced your crankshaft and waterpump pullies lately? They wear, and the belt bottoms out and slips, causing poor cooling.
msb
04-18-2006 20:51:55
Runs how warm? Have you stuck a thermometor in the radiator? The temperature sender is located in the hottest part of that engine and it may not be running as hot as you think.I doubt if there is anything wrong with pump.Has your injection pump been set up? That will certainly cause a 4320 to run warm.
Your air conditioner could be low on freon .The low pressure switch will keep the clutch on the compressor from engaging in that case.
