420U how many made
schmidtg99
04-18-2006 19:17:58
i dont know anything about 420's but how many 420U's were made. also it has a lever to go from forward to reverse without shifting is that common. what is it worth it needs new rear rims everything is stuck on it, it also has power steering but the power steering resevoir ( i assume that is what it is) has froze and cracked. any help would be appreciated. thanks
schmidtg99
04-19-2006 19:54:59
 Re: 420U how many made in reply to schmidtg99, 04-18-2006 19:17:58
the problem is the tag is gone on the tractor. the hood does have the yellow stripe and it does have slant steering but she is real rough any idea on value?
Ten-Twenty
04-20-2006 03:48:03
 Re: 420U how many made in reply to schmidtg99, 04-19-2006 19:54:59
The slant steering makes it a Phase III (only 1114 built). The missing serial number plate reduces the value. It is possible to go through your JD dealer and get a replacement tag (has a bar code and looks nothing like the original). It is worth what someone is willing to pay for it in the "rough" condition you say it is in.
George S. in the real NY
04-19-2006 04:35:18
Have you checked the ID tag? I just checked the parts book and the reverser was available on S,T,U,W,& C after sn131309. That would be a late 420. In any case, it would be a great tractor to fix and have. PS and Reverser OOOOH I'd like to find one. Better grab it!!
Ten-Twenty
04-19-2006 06:19:50
 Re: 420U how many made in reply to George S. in the real NY, 04-19-2006 04:35:18
George,
Actually, the direction reverser was available starting with the early 420U (Phase I). Schmidtg99 will need to check the serial number to determine which model 420U he is looking at.
04-19-2006 20:41:40
 Re: 420U how many made in reply to Ten-Twenty, 04-19-2006 06:19:50
Yup, you are correct. Further back in the parts book it does list the reverser parts for early 420. I was looking at the center frame parts list. I missed finding a center frame for the earlier tractors. Used the same with or with out?? I guess they did. Anyway, the slant steering wheel would be later.
Ten-Twenty
04-19-2006 03:49:59
There were a total of 4932 420U's built (1963 were Phase I - all green with vertical steering, 1855 were Phase II - green and yellow hood with vertical steering, and 1114 were Phase III - green and yellow hood with slant steering).The direction reverser and power steering options add value.
