Crankshaft End Play?
Jason(Pa.)
04-18-2006 18:19:15
Im trying to get the End play on my "A" set and I can't seem to get the flywheel in far enough to get the right amount. I got it to slide in more then where it was first off,but it still needs to go a little more. Im hitting it,pushing it and nothing seems to be moving. Any ideas on what may be the problem? Thank You!
John T
04-18-2006 18:40:07
 Re: Crankshaft End Play? in reply to Jason(Pa.), 04-18-2006 18:19:15
Jason, how we do it is for one person to hold a large sledge hammer tight up against the big end bolt over on the clutch driver side while a guy on the flywheel side uses a big oak block and a sledge to drive the flywheel in to her milk. Works for us.
John T
Jason(Pa.)
04-19-2006 02:53:42
 Re: Crankshaft End Play? in reply to John T, 04-18-2006 18:40:07
Ok,thanks. I'll give that a try.
