JD B Power Troll Quit
Bob Linscott
04-18-2006 17:43:27
Would like some trouble shooting ideas on the problem with my 1950 B power troll lift. I only use the tractor 6-8 times a year and last Nov the lift was operating OK. Today it only moved a nudge backward and nothing forward. I checked the oil level and it was only down a pint. I only have the owners manual & that doesn't help. Any ideas what I should check out?
Glen in TX
04-20-2006 18:39:46
 Re: JD B Power Troll Quit in reply to Bob Linscott, 04-18-2006 17:43:27
Also make sure the oil isn't milky with water in it. Air and water in the system can blow out orings. Water freezing in oil or system in cold winter storage can also cause problems. Sticky valves and sticky relief valve can cause problems too. Sticky pedal or levers or worn or broken cam mechanism inside can also cause it to not work or broken springs.
Bob Linscott
04-19-2006 16:34:10
Thanks for the responses & info. The PTO shifter was to the right (off) position. Thought it would be a go but was a no go. When I push the powr-trol lever to raise I can hear a low whine at the pump area, nothing when lever at drop position. The sound is similar when a hydrau pump doesn't get enough fluid. Could it be a blocked vein? I have a mechanic friend who has an electronic bath cleaner, would this pump be a candidate for a bath? My B does not have the power lift and the PTO works smoothly. I don't see fluid on the casting but it must leak some on the dirt floor as it lost about a pint in 6 months. I use SAE 30 oil as did the previous owner. I have never worked it hard at all. If no obvious fix is known I will order the JD Hydrau svc man. I would never have gotten this far without you guys. Thanks again, Bob in So. Maine
Leroy
04-19-2006 18:57:49
 Re: JD B Power Troll Quit in reply to Bob Linscott, 04-19-2006 16:34:10
The PTO has to be running for the hydrolics to work and the Power trol is just a more complicated valve than the power lift that can start or stop the raise of the power lift shaft for cultivator or also with different settings can be used with a remote cylinder. Check that the PTO shaft is turning when you try to operate the lift and also check the hydrolic oil level at the petcock and with both it should work
Bob Linscott
04-20-2006 01:36:58
 Re: JD B Power Troll Quit in reply to Leroy, 04-19-2006 18:57:49
Thanks for getting back on this problem. The PTO was operating and the oil level is up. I can hear a light whine at the pump when I put the powr-trol lever to raise. The system was working fine last fall when I parked it in my shed. Any thoughts for follow-up? Bob in So. Maine
Leroy
04-20-2006 16:46:34
 Re: JD B Power Troll Quit in reply to Bob Linscott, 04-20-2006 01:36:58
Now I would have no idea
Leroy
04-19-2006 04:34:54
That nudge backward would be by spring pressure. Sounds like you may have kicked the PTO shifter out of gear as the PTO has to run for the hydrolics to work unless you have the live hydrolic option and never seen one on a B, only on a couple of A's so it is doughtfull that you have that but possible then they have a shifting lever on the pump to turn it off when not needed
Glen in TX
04-18-2006 21:43:15
Powr trol for cylinder? or Power lift for rockshaft? Tell us which one and more about problems or things done so far to trouble shoot. Piston cup leaks, valve or housing leaks, bad orings, low oil, too heavy a oil, too light oil. I&T JD-4 shop manual has some coverage on it but the JD SM-2011 Hydraulics service manual covers it much better if more repairs are needed.
