Getting more power from a 4240
spudddie
04-18-2006 15:52:18
I am looking at buying a John Deere 4240, but I would like to get a little more horsepower from it. What is the cheapest, easiest and safest way to get more power. The 466 engine is capable of putting out a lot more hp. in the larger model tractors.
Thanks
msb
04-18-2006 20:43:56
 Re: Getting more power from a 4240 in reply to spudddie, 04-18-2006 15:52:18
Some geat advice here.I hope you listen.Don't you think if the 4240 was capable of safely generating more horsepowewr Deere engineers would sell it as a feature especially if all it meant was to turn the pump a a little.Sure they build in a bit of a fudge factor,but it is for your protection as much as anything.Don't jepordize the reliability of a great tractor because of some bragging rights that may fly back in your face.If you truly need more horsepower, then buy a tractor that will produce it with the reliability and longevity of service to go with it.This is from a person who has set up hundreds of pumps in the past.
buickanddeere
04-18-2006 20:32:43
There are three words together which are often heard prior to a disaster. Quote "cheapest, easiest and safest way", unquote.
jared in wi
04-18-2006 19:47:43
Ralph said it best, if you get a 4240 and up the Hp, eventually you will have major transmission problems and you will be buring out the clutches all of the time.
the way i see it, if you want more power, get a model that is built for it.
Jared
RalphinWI
04-18-2006 19:30:46
Easiest, cheapest and safest???, how much more power do you want? Opt for a 4440, 4640 or 4840. Although the engines have the same displacement, they are built with different components. Likewise for the rest of the tractor components.
