2030 Hydraulic Issues-Any ideas?????????????????
JB KARCH
04-17-2006 19:41:13
The hydraulics on my 2030 have been progressively less responsive over the last year or so. Now when I start it up it"s 2-3 minutes before anything will move & then it"s very slow and pulsates. If I"m using PTO I"ve got about 2 hours starting with the bucket all the way up and it settles down and won"t lift again. Kinda inconvenient for bush-hogging. Just looking for ideas. I"m thinking it needs to go to a dealer for diagnosis but hobby farming a little chunk of CRP really doesn"t justify a lot of expense. Thanks in advance for any input----- -D_GEEK
ET
04-19-2006 07:03:31
 Re: 2030 Hydraulic Issues-Any ideas??????????????? in reply to JB KARCH, 04-17-2006 19:41:13
Does your tractor have a high-low shift on the dash or the hydraulicly engauged pto? These options and others are supplies with charge pump oil through internal steel lines. The lines are known for cracking and breaking. Then the main pump is not supplied with enough oil to operate other functions like remote outles and the rockshaft.
Hayfarmer
04-18-2006 07:36:21
If the hydraulic oil gets really hot there may be an internal leak. If you have remotes on the tractor where you hook loader, the valves inside of them are really touch as to adjustment and could be worn. A brake valve or steering valve that leaks, internal, can cause this also. If you don't have a familiarity with it and the filter change doesn't work, take it to a JD dealer.
Mike M
04-18-2006 06:35:23
Check the filter and the suction screen. And look closely for metal flakes if you have lots of them the brakes may be shot.
Dairy Farmer
04-17-2006 19:45:26
have you checked the Hydralic oil and seals to see if it has enough oil and if it is leaking anywhere? That is usualy the prob on our tractors.Just a thought.
