'44 JD Model B Brake Linings
Steven Koldewyn
04-17-2006 09:39:30
I'm looking into replacing the brake linings on My Model B. Is there a prefered method or tool for applying the rivets?
Glen in TX
04-17-2006 21:46:53
 Re: '44 JD Model B Brake Linings in reply to Steven Koldewyn, 04-17-2006 09:39:30
Several kinds of rivet setters out there and methods as listed below to do it. I have tool similar to the one in these links and can take the punch out to do them out of holder too and it works great. Leather crafter stores also sell rivet setters. If you don't rivet anything much best to just take it down to a shop that has a rivet press and let them do it.
cleavelandtoolstore.com
aircraftspruce.com
Kurt_JDB
04-17-2006 20:03:28
Steven,
I have had great sucess using a transfer punch. I think it was the 5/16 size. The shape of the tip is perfect for curving the rivet over. I put a straight punch in a vise to back up the rivet head, and had a friend hold the shoe. A few taps with a hammer on transfer pucnch would set the rivet. I was using the aftermarket shoes, which are brittle, but had no problem.
Good luck.
Kurt
Skyhawk Greg
04-17-2006 13:01:57
Steve, First of all, be careful with the new linings as they are easy to crack if you apply too much clamping force when installing the rivets. The brake kit is still available from the dealer, complete with rivets. There are several ways to seat the rivets. One way is to use a center punch while backing the rivet up with a steel rod. Be very careful, and use patience. Several taps of the hammer will not quite seat the rivet, and, all of the sudden, the next tap, if too hard, will break the lining. Another method is to modify a C-clamp so that it applies a uniform and gradual clamping force. I myself used to use a similar device that was made from a leaf spring seperator. The last, but best method is to use a rivet setter. They show up at flea markets and antique shows with quite a bit of regularity. I bought three of them for about $2.00 each. This is much cheaper than buying the second set of brake linings after you have cracked the first set. If you live in northern Ohio, let me know, and you can stop by, and we can set your rivets. One last thought. The universal brake lining set may have linings that are longer than the ones you removed. Just cut them to the proper length with a hacksaw and chamfer the ends. They will work. Good luck!
Wind
04-17-2006 10:39:32
I have often wondered how an aluminum pop rivet would hole up there?
When I did my '35, found that a center punch into the center of the rivet first on the back side helped to start the rivet and finished with a ball peen hammer.
