JD B 1940 overheating
ironhorse
04-17-2006 08:12:49
I have a 1940 B that i use to farm with and I dont know if I am working it too hard or I have a problem I pull a two bottom 14 plow or a 8 foot disk. it works for about 30 to 40 minutes temp gauge climbs steady and then once it get above 212 the engine starts to miss and run bad so I stop unhook and wait for another day. It does this reguardless of the out side temp say when it 50 degress or above if its hotter out it just does it quicker. These where the attachments I bought the tractor with that the old farmer use for it's life. rad fins are clean and nothing to block are flow on the screens. thanks for any help
DickD
04-18-2006 01:00:38
 Re: JD B 1940 overheating in reply to ironhorse, 04-17-2006 08:12:49
Hello Ironhorse; Just a little insight from an old 39 B operator. We used an Oliver Radex 2 14 in. pull type plow, and disked with a 7 ft John Deere disk. Sorry to use the Oliver name, but it did a good job and pulled easy. Most of the time we could run in 2nd gear, unless we were in heavy ground, and then it would start to heat up. Normally, when we shifted down, it was fine, and would cool back down to running range.
johns48b
04-17-2006 13:25:41
check your fan belt to be sure it isn't to loose. also check your timing and be sure your radiator shutters are open. even if radiator looks clean i'd wash the radiator fins off real good. you may have to pull the radiator and have it cleaned (last resort)
Sambo
04-18-2006 14:06:30
 Re: JD B 1940 overheating in reply to johns48b, 04-17-2006 13:25:41
A 39B doesnt have a fanbelt just for the record
Mike M
04-17-2006 09:56:35
It's not unusual for a thermo siphon system (no water pump)to run near boiling under a load. You may have some other problems,like plugs,coil ? have you tried opening up the carb. load needle ? adjusted the valves ? Many things to check out.
ironhorse
04-17-2006 10:40:27
 Re: JD B 1940 overheating in reply to Mike M, 04-17-2006 09:56:35
wouldn't these should up bad running even at a lower temps. just asking how much would you suggest opening up the load needle. thanks for the suggestinons
Mike M
04-17-2006 10:52:17
 Re: JD B 1940 overheating in reply to ironhorse , 04-17-2006 10:40:27
Turning it open 1/4-1/2 a turn should show some kinda change. If too lean a mixture was the problem it may straighten it out and if not it should now run too rich and blow some black smoke. Don't overlook the fact it may be as simple as a bad spark plug too. Try a brand new set and see if anything is different.
