'44 A valve adjustment
Dave Siekkinen
04-17-2006 08:05:23
Can someone give me the specs on the valve adjustments for my 1944 A? Also, can someone walk me through the steps for adjusting them, as I've never done one of these tractors before? Thanks for any info.
Glen in TX
04-17-2006 19:02:06
 Re: '44 A valve adjustment in reply to Dave Siekkinen, 04-17-2006 08:05:23
A JD operators manual or a I&T JD-4 shop manual would have that info plus more for you. A JD operators manual will tell you to adjust them while cold. Remove the tappet cover from head and both spark plugs from the cylinders. Turn flywheel forward until the piston on LH flywheel side is on end of compression stroke. Adjust the two left hand tappets by loosening adjusting nuts and turning adjusting screw on tappet lever out and then back in until there is no shake or movement in the lever. Then turn the screw back out 1/3 turn or until .020" clearance between tappet lever and valve stem. After adjusting each one retighten the locking nut. Then do the RH valve also and replace the tappet cover using a good or new gasket. You can get JD manuals on paper or CD having them combined on one CD also. Others may tell you to adjust them at .022" hot.
Dave Siekkinen
04-18-2006 03:59:27
 Re: '44 A valve adjustment in reply to Glen in TX, 04-17-2006 19:02:06
Thanks for the info, Glen. I misplaced my tractor manual and haven't found it yet.
