39 B hard starting
mgb
04-17-2006 03:38:42
Hard to start b. Ran load and idle pathways test on Carb. Passed both, pathways are open. What is next to check?
mgb
mgb
04-17-2006 11:41:23
 Re: 39 B hard starting in reply to mgb, 04-17-2006 03:38:42
This tractor is hard to start from the git-go. I haven't had this tractor very long. It is hand start and I'm too old to turn the flywheel very many times. It had new plugs and new wires when I purchased. When I get it running, it runs smooth when the load needle is almost closed. If I start to open the load, it starts smokeing (Black)and almost backfires. Thanks for any info.
mgb
John T
04-17-2006 12:45:41
 Re: 39 B hard starting in reply to mgb, 04-17-2006 11:41:23
mgb, Under no load conditions the Load Needle could be fine opened maybe as little as 3/4 turn out, so what you say doesnt surprise or worry me. I would start at having the load needle out around 3/4 turn and the idle needle maybe 1 1/2.
As far as ease of hand crank starting, heres my advice: If shes low on compression which is causing hard starting, you may try removing the plugs and squirtign some oil in the cylinders first.
1) Regardless if they were new at one time, I would install NEW plugs, check the point gap, and clean/buff/polish the points non abrasively. If, however, they are burned or pitted or badly carboned, I would replace them. Be sure it has wire core NOT carbon core suppressor wires, insure if a mag it has a loud sharp distinct SNAP as the flywheel is cranked and that BOTH plugs yield a good visible blue and NOT a faint thin wimpy yellow spark. If its a Mag and if the mag has a weak spring (faint dull clunk versus loud sharp snap) that causes a weak starting spark and hard starting. If pull started she starts n runs just fine but has a weak starting spark on a Mag ignition, I suspect a weak spring.
2) Check the start timing, if too fast she may kick back but if too slow she can be harder to start. I would set a mags start timing so it snaps to fire just as the Flywheels Left Hand Impulse timing mark passes by the flat mark on the tractors side at the 3 o clock position, maybe even just 1 to 3 degrees before, so long as not to early causing flywheel kickback.
3) With fresh clean gas, I would just crack the throttle open above idle,,,,, ,,close the choke,,,,, pull the flywheel over NOT OVER TWO compression pull overs,,,,, ,,,open the choke,,,,pull her over n see if she starts.
If that dont help give her 2 aspirins n call me Monday at the Office.
John T
P Browning
04-17-2006 05:47:04
As Mike said, it seems no two tractors are alike. Try this tip from Field Service Bulletin 200-S. ----- ----- --
TIP: Start Engine With Nearly Closed Throttle
Most tractors start easily, however, there are those one of two in a hundred that give trouble. In most cases, these can be improved by placing the throttle in an almost closed position.
The higher velocity of air entering at the edges of the throttle disk helps to vaporize the mixture of fuel and air and keep it in a volatile state for starting.
With the throttle nearly closed, the amount of air-fuel mixture entering the cylinder is limited, lowering the compression.
With lower compression, the spark will more readily jump to gap at the spark plug electrodes; battery load is decreased, causing a hotter spark; and cranking rpm is increased (FSB 200-S, February 1953). This technique works equally well for hand-start models -- seems to help avoid flooding.
Wind
04-17-2006 05:16:45
Is it hard starting from the get go or when restarting after shutting down? My '35 does not like to start when warm, but cold will start right off.
Does it run right once started? That would rule out limited flow to the carb, have you checked out the flow once you turn on the gas?
I always turn off the gas at the sediment bowl when shutting down, making sure not to have a flooded cylinder when starting the next time.
Also check for a strong blue spark at the plugs, any thing less and you will have problems getting started.
Mike M
04-17-2006 05:03:39
Compression/cylinder leak down and the ignition.
Maybe just a matter of starting or shut down proceedure ? No 2 tractors start alike.
