Deere F560H plow
Richard Fazio
04-16-2006 19:48:55
I need a part and I'm hoping the Deere guys here can tell me if it's still available from John Deere. I don't even know what plow I have. The best I can make out from what's left of the painted on model number is F560H. It needs one new part. I don't know what it's called, but it's the part that all the parts that make up the bottom bolt to. Then this center section bolts to the frame of the plow. The plow is a 50's I think 4 bottom and it has a cylinder to lift it. Here is some pictures of it when I was stuck in the mud, don't mind the Farmall pulling it. Thanks for any help. I've had no luck at the bone yards. They all want to sell me another plow.
Bill-NNY
04-17-2006 08:45:44
 Re: Deere F560H plow in reply to Richard Fazio, 04-16-2006 19:48:55
The bottoms are listed in a separate parts book.
Depending on the bottoms that are on your plow, the parts book could be PC158 or PC1308.
If you can find a part number on the back of one of the moldboards, I can help determine the type of bottom that you have.
Bill
RalphinWI
04-17-2006 05:53:16
The item at the bottom of the standard (shank) that the moldboard, share and landslide bolt to is known to me as the "frog".
Carl NY
04-17-2006 01:24:53
I believe what you have is a 650H plow. It looks like it was originally a five bottom reduciable to 4 bottom. I have a 5-16 plow same model. If I understand your question you need the shank that bolts to the main beam. You may have to buy a junk plow for parts.
Richard Fazio
04-17-2006 05:35:05
 Re: Deere F560H plow in reply to Carl NY, 04-17-2006 01:24:53
Carl, It was a 4 bottom changed to a 3 bottom. Is the shank the part that hangs down from the beam and kind of comes to a point? That is ok on mine. To that bolts a angular shaped piece, two pieces welded together I think. This welded piece takes the landslide, the share, and the moldboard, if I'm naming them correctly. Here is a picture of the plow model number. You'll see why I thought it was 560?
Glen in TX
04-16-2006 21:55:55
Are you sure you got the model number right? I'm not finding anything on a F560H but JD did make a F650 series plow and F660 series plows and didn't find a online manual for those at http://jdparts.deere.com so try a dealer with the correct numbers. JD publications has manuals for F650 and F660 plows.
Richard Fazio
04-17-2006 05:36:56
 Re: Deere F560H plow in reply to Glen in TX, 04-16-2006 21:55:55
Thanks so much for the info Glen. I'm going to order the parts disc.
Glen in TX
04-17-2006 18:37:28
 Re: Deere F560H plow in reply to Richard Fazio, 04-17-2006 05:36:56
Richard, Your pic above looks like it shows F660H (H for hydraulics). I should have knew that when seeing the square tubing beam across the top of plow. OMA12323 operators manual covers F640,F650 to F660H plows and parts catalog PC684 covers F640,F650,& F660 plows. The CD disk is a good way to go and you can get them combined on one disk. Like Bill says above you will need number off moldboards to ID those in seperate books that he listed.
