Aluminum pistons --JD 50
Tye W
04-16-2006 17:47:55
If I install additional length aluminum pistons in my 50 will I get get around 35 horsepower or better? I am considering buying a powerblock and then installing aluminum pistons. Could that conbination put me over the 40 horsepower mark? What are some good ways to increase the horsepower on my 50? I am working this tractor, another tractor is not an option at this time. Thank you for any help. --tye
Mike M
04-16-2006 19:41:20
 Re: Aluminum pistons --JD 50 in reply to Tye W, 04-16-2006 17:47:55
I had a 50 that should of been stock except it may of been .045 oversized and it made 31 HP. Had a late B with M&W add power pistons and I think it may of made it up to 35 HP. So a little work and some High octane gas and some fine tuning 40 HP should not be far off ?
buickanddeere
04-16-2006 22:48:59
 Re: Aluminum pistons --JD 50 in reply to Mike M, 04-16-2006 19:41:20
If it runs without knocking on 89 ocatne gasoline. Filling the tank with 94 octane will slightly decrease the HP. Best,cheapest & reliable way to get more HP out of a 50 is to trade it for a 520/530 or 620/630.
Mike M
04-17-2006 05:13:25
 Re: Aluminum pistons --JD 50 in reply to buickanddeere, 04-16-2006 22:48:59
I am in total agreement with the fact if you want more power buy a bigger tractor !
But these guys like monkeying with these engines milling heads and blocks adding pistons from god knows what in an attempt to jump the compression pressure up. Many go too high and even the high octane won't stop the knocking. I have a dyno so I get a few locals who tinkered all winter long trying to gain more HP I am amazed that most of the stuff they do they gain very little or loose power. Then I have to go back and set the timing (running) and carb. and seem to get the most gains from proper adjustments.
jd b puller
04-16-2006 18:30:18
Tye, a Powerblock already has Aluminum pistons. Should get you around 35 HP. What are you using the tractor for?
Tye W
04-17-2006 05:41:29
 Re: Aluminum pistons --JD 50 in reply to jd b puller, 04-16-2006 18:30:18
B Puller, I use this tractor doing chores for myself and my neighbors. Spreading manure, bush hogging, plowing, discing, cultivating, and planting. And since this is my only two cylinder tractor, I take it to the stock antique tractor track a few times a year. The other guys mentioned that it would be better to get a bigger tractor. I totally agree with that philosphy only this tractor has a lot of centamental value. It's been in my immediate family for over 20 years and before that it was at my dad's uncle's chicken farm since new. My father remembers riding it when he was a little boy. If it were any other tractor I would gladly sell it and buy a bigger tractor. This tractor has never been overhualed since it's been with us (20+ years) and it was dynoed last winter at 22 horsepower. It has a lot of blowby (cracked ring?). 35-40 horsepower is all I want. I think a powerblock is what I am looking at buying.
Mike M
04-17-2006 11:12:01
 Re: Aluminum pistons --JD 50 in reply to Tye W, 04-17-2006 05:41:29
Just save the money spent on a power block (if you can even find one) and use it to do a good and proper overhaul. You put everything back to specs. and your going to get the power you want back. Just use whatever NEW oversized pistons you can find that match original specs.
buickanddeere
04-17-2006 11:25:09
 Re: Aluminum pistons --JD 50 in reply to Mike M, 04-17-2006 11:12:01
I suppose he could do a little tuning if he understands he is reducing reliability. A set of model 50 LP pistons, a cam from Roberts carb, a dry airfilter conversions, five angle valve job, port matching and valve bowl blending. This might get a 50 into the 520HP range without being too radical.
